#21
you going t use cub axels and hydro's?
#22
Great advice, and I think a pillow block bearing on each part of the driveshaft that's connected to one of the transmissions would be a good idea. I can see a rather long unsupported length in your latest picture...that will put some bending loads on the shaft it isn't designed for, particularly if the shaft binds, and it would probably vibrate a lot too if there is any slop between the U-joint shaft, sleeve, and input shaft.
#23
Yep, I have 2 - 1711 rear axle assemblies.
#24
One other issue is keeping the shafts parallel with a U-Joint type drive line. Otherwise you will need to use a CV type joint.
#26
Why is that a problem with 2 U joints, but not with 1?
#27
In the drawing I did I should have explained that the black lines represent the driver and driven shafts and the red line is the drive shaft itself. Picture a U-Joint at the intersection of the red and black lines. This will explain how U-Joints work in more detail.
http://www.hurst-drivelines.com/file...roc_111606.pdf
#28
The input into the drive line & the output have to remain parallel? So a full size articulating tractor only have one U joint in-line with the pivot point? What happens wen the front & back rock? Something has to give, another U joint would be needed. Rock: |
#29
My suggestion is that you find an articulating loader and take some pics of the drive line so that you can copy how they designed the drive line.
#30
A couple of good working articulaters,
