Old 08-13-2018, 09:40 AM
farmall fred's Avatar
farmall fred farmall fred is offline
Here are some from the 1872 I rebuilt as my main mower. The PO was a real cobble artist. When he quit using the 1872 because the input shaft on the hydro was leaking because of a bad driveshaft he jury rigged the 60 in haban under a Farmall cub. I just wish I had thought to take a picture. here is some of his fine work.
Note the brass shifter knob and the dash plastic repaired with aluminum flashing.
The use of a household light switch to activate the pto,
Front of trans case with a welded repair with threaded rod to attach to front hanger. The axle tubes had been repaired with oversize bolts with nuts inside the housing.
I wish I had taken more of some of his work. Sad thing is he had receipts for many high dollar repairs done by a local shop that either ripped him off or he was so abusive that the repairs did not hold. Motor was rebuilt with new jugs and pistons and the next year the motor was repaired again with one cyl overbored.
Old 08-13-2018, 09:44 AM
sorner's Avatar
sorner sorner is offline
A light switch
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 08-13-2018, 10:36 AM
Dirty Steve's Avatar
Dang!
You didn't have to pay for that rig did you Fred?
Old 08-13-2018, 10:40 AM
cooperino's Avatar
Is that a 10 or a 15 amp switch ??? LOL
Old 08-13-2018, 01:45 PM
Originally Posted by sorner View Post
A light switch
. When I went to look at it I could not believe it. he seemed proud of how he fixed it, you should have seen the wiring!!!!!!
[QUOTE=Dirty Steve;463609]Dang!
I bought it at a very right price. After I got the engine running well after grinding the valves it became a donor for a 782 I had with a blown KT-17
I repaired the hydro with parts from a 1964, added a 28hp EFI command engine and built the tractor into this one.
Link to build.
https://www.onlycubcadets.net/forum/...ad.php?t=43432
Old 08-13-2018, 01:47 PM
If I recall it was a 15 amp switch.
Least he could have done was sprung for a color matching switch plate!!
And maybe a mounting box!!
Old 08-13-2018, 11:04 PM
john hall's Avatar
here is the fuse from my 1811. No, nothing got fried.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 08-14-2018, 09:02 PM
Gompers Gompers is offline
Picked up this 782 last weekend....
QA tabs are welded in the front too... I will say it’s entirely functional for it’s purpose.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 08-14-2018, 09:50 PM
Looks like it has a rear spoiler
