Old 08-10-2016, 10:09 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
radiator cap hold pressure?
correct psi cap on it?
was it a new radiator or just a cleaned up unit?
have you checked for combustion in the cooling system?
have you done a bubble test to the cooling system?
are there any other coolers in front of the radiator or in the radiator that could be causing heat to raise the coolant temp?
Old 08-10-2016, 10:12 PM
yes
yes
new
the head was check for cracks and it got a new head gasket
no
no other coolers
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-10-2016, 10:17 PM
john hall's Avatar
You mentioned earlier about the block being plugged. Anybody ever had trouble with this engine leaking water and pour a lot of stop leak/block seal into it? We went into a Ferguson once that had had a bunch of that stuff dumped in it, what a mess. I also dumped a bunch in a combine trying to stop a leaking sleeve o-ring. Both engines eventually had to come apart and be reaired correctly---cleaning out the inside was no fun! I may have missed it but is the radiator new or has the old one been sent to a radiator shop to have it rodded out?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 08-10-2016, 10:24 PM
i wasn't around when they popped the freeze plugs out so i didn't get to see the inside, i was told it didn't look bad but you really cant see everything through 2 holes. the rad was brand new.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-10-2016, 11:04 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Check your temps in multiple places tomorrow and report back. I think I agree with Don, check for CO in the coolant. I know the head has been checked but maybe you have a bad gasket. Will it get hot idling, or do you have to put a load on it? Does a fast idle make it heat up quicker? Just thinking.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 08-10-2016, 11:31 PM
I was also wondering if at some point someone dumped a bunch of "block seal" (or whatever) into it trying to fix leak at some point.
I too have seen a build-up around the sensor preventing coolant from contacting it.
Does the owner give you any idea of how long this has been going on? Maybe since the engine was rebuilt, or maybe even before?
I would also think about the water pump impeller being for the opposite direction.
I'll have to go back and read the thread again, I don't remember if coolant circulation was verified.
Old 08-11-2016, 05:33 AM
twoton twoton is offline
New sending unit?
Old 08-11-2016, 07:38 AM
I've used Redline water wetter in my race cars and it helped 10-20 degrees.
http://www.redlineoil.com/product.aspx?pid=74&pcid=10
Old 08-11-2016, 08:09 AM
Originally Posted by twoton View Post
New sending unit?
It's a mechanical gauge.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-11-2016, 08:11 AM
We already tried that and it didn't help.
Pap's 100
Restored 108
1211 Dual Stick
1050
