Old 04-15-2014, 07:26 AM
Littletractors Littletractors is offline
Default Home made bedder attachment
Heres one I made. Good for small stuff
OOPs sorry, not mine, will have to re-look my pictures
Old 04-15-2014, 11:20 AM
Welcome to OCC! Nice job on the attachment, and nice QL!
Old 04-15-2014, 06:11 PM
Welcome to OCC!
Old 05-30-2014, 03:13 PM
Peruvian Peruvian is offline
After using mine for a few years, here are some thoughts;
-I should have angle cut the short pipe to lift the T up higher off the ground
-I traded out the 14" discs for 12" as a result of ground clearance issues and it works better (anyone want to by 14" discs and shanks?)
-down pressure is needed, so be sure you don't float too much.
Otherwise, it's an easy project, doesn't costs too much and works well. I do like the idea of a bedder a foot or so behind the discs.
Old 05-30-2014, 10:33 PM
larry03061976's Avatar
larry03061976 larry03061976 is offline
Looks good gentlemen!
Old 07-25-2014, 10:31 PM
Tim.E's Avatar
Tim.E Tim.E is offline
Where do you guys get those hiller/bedder discs/shanks?
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 07-27-2014, 02:45 PM
john hall's Avatar
Agri supply carries a good line of cultivating parts. If you are not familiar with the IH offset series tractors, do a little research on Cubs-140's.
If you are building a cultivator make sure the clamps work with your bar and shank size.
Here is a link to something like you want, you'll have to figure out the specifics to your application.
http://mower-blades.agrisupply.com/s...0hillers&asug=
http://www.agrisupply.com/lay-off-cl...06/&sid=&eid=/
