#21
I got some help from friends but ive not built a motor from a bare block. I did find a 40 over piston from the guy you recommended on the other post. I found the information on the pin height and rod length on another web site. ive read all I can find about kohler k motors. it does seem to be limited info on building engines for pulling.
#22
It's best if you get the pin height and rod length from the seller of the part, or the manufacturer. 3rd party websites are not reliable.
So..... did you read your rules for the club you want to pull in yet? What's your budget? |
#23
yes a 60 over is allowed in pro stock class for 16 hp. im rebuilding a stock 1200 right now. ive restored other cubs to original condition and it seems to be hard to stay in budget on a build.
#24
However as mentioned you will need to get the correct rod and piston combo. You also need to take the club rules into consideration. |
#25
How close to 4"? 3.900"? 3.800"? 3.999999999"?? You say a 13 fin. What about the 12 fin? |
#26
According to MWSC you can bore a k341 to 4" no problem.
#27
Either? Or just a 13 fin?
They are different blocks. You can bore some 241's to 301's, but not all. |
#28
mwsc has a video on kohler k blocks. I believe they recommend a head strap when the 13 is bored near 4 inch.
#29
Yeah, gotta head strap them when you bore one that big. I've heard of guys going a far out as 4.055 on a 13 fin block. Not sure what i would risk on a 12 fin.
#30
I have a k241 engine here that says k301 on the front, came out of a 104 I junked about 8yrs ago.
