Old 02-04-2018, 10:02 PM
Merk Merk is offline
Hitches like the one in post 10 scares me. I can haul 160 pounds of water softener salt in my carry-all and have a light front end.....too easy to put the front end 3 plus feet in the air.
I would build-use a trailer dolly like this one.
https://www.northerntool.com/shop/to...2627_200512627
The handle would be modified so I can hitch it a a Cub Cadet.
The majority of the weight is on the dolly's wheels. The front of the tractor has a better chance of staying on the ground.
Project Uncle Dick
Cub Cadet 70
Old 02-05-2018, 02:40 PM
Poser Poser is offline
Will this solid hitch pull my boat
Daily driver at work, note! It's an International.
Kevin
Old 02-05-2018, 03:50 PM
jbrewer's Avatar
jbrewer jbrewer is offline
You can go up and down hills with that one!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 02-05-2018, 05:35 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I don't like that hitch either, the ball is too far behind the rear axle.
The hitch I made with the 3-point bracket puts the ball much closer to end of frame. Plus it bolts to frame with seven bolts.
Old 02-05-2018, 06:15 PM
yettrbomb yettrbomb is offline
Above everything else, just remember what you’re pulling with. Regardless of how well made or attached to whatever, it’s still a 6-700 pound cub. Accidents happen quick, be careful and good luck.
Old 02-05-2018, 07:02 PM
I will operate as safe as is possible, definitely aware of how fast things can get away, I drive very boring watching everyone else drive like idiots.
If the 106 won't move the boat, then I will attempt some kind of carry all I have seen in other threads.
I like rigging things and eventually have creations that actually work!.
The carry all theme has me thinking, maybe I could rig something to that, man I love playing with this smoky old Cub. Be blessed,
Kevin
Old 02-05-2018, 07:05 PM
Me either, it places to much faith on one mounting surface, my design places load over a much broader area, a little more fabricating and it will be ready to permanently mount.
Thanks all!
Kevin
Old 03-25-2018, 03:12 AM
Getting closer, have decided not to pull boat on trailer, since I have no other use for my large toy I'm thinking of a large Carry all on back.
Getting ideas directly on homemade here! I want to play with my toy!
Kevin
Old 03-25-2018, 09:10 AM
Sounds like it's time to start looking for a lo-boy Cub in order to get a little more heft into play here.
