#21
SureGrip, good luck with your repairs. Let us know how it turns out. I agree, I thought the pictures on this thread were amazing. One more reason to keep grass out of the cooling fins!
And Welcome to OCC!
John Proud Owner of a Model 100 and a Model 124. A homemade cart, 2 x 42" mower decks, a 38" deck, a 42" front NF blade, and a lawn sweeper! |
#23
Thank you for the warm welcome!
I was able to get the gaskets and impulse tube from Repair Clinic . com and will be putty Humpty Dumpty back together today. I saw the question posted earlier in this thread, but never saw an answer. Does anyone have the torque specs for the head bolts? Thanks again, and I'll let everyone know if she fires back up again. *fingers crossed* |
#24
Well...put it all back together, crank it over, and nothing out of the pump...
So, I try priming the pump, ensuring that there is fuel to the pump...I'm barely getting anything coming out of the fuel line, even when it's just hanging free...it should be pouring out of the hose. So, I go to the source, open gas cap to make sure it's vented, still barely a drop coming out. Climb under the tractor and start inspecting the fuel hose to see if it's kinked or pinched...sure as sh**, the little plastic ring that holds the fuel hose to the frame rail, right behind the left-rear tire, had broken and allowed the hose to get caught between the deck bracket and the underside of the frame, pinching it nearly closed.. Pull it free and check to see if it is damaged, all looks good, so I crank it again, and now fuel is shooting out of the pump. I'm pretty sure the whole neighborhood heard the f-bomb I yelled out. So now the battery is on the charger, and it should be ready to fire in an hour or so....either that or I'm going to burn it to the ground. Oh, and the torque spec for the head bolts is 220in/lbs or 18.333 ft/lbs |
