#21
Your 1782 has the CV style shaft, just make sure you grease it a couple times a year and it will be happy. I'm sure you know that the shaft has grease fitting in it that direct the grease into the joint.
#22
Yep Sam. I knew it had the CV joint. I meant to say I hadn't rebuilt it yet. Figured I'd pull it apart and clean things up good and replace anything needing replaced. Then grease it well. She's alittle sloppy and vibrates. Haven't looked into it yet. Too many projects, too little time.
Josh Diesel Cub Cadets........... |
#23
if ya need one i have one lying around PO had just replaced front end of shaft just before i bought it i put in a cv style shaft if ya want it pm me here should be worth 60 bucks plus shipping
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
#24
So let me get this straight, you have a 782D with a CV style front? Got any pics of that?
3 original cubs 1512 diesel Ingersoll 3012 John deere 855 |
#25
no i took a 782d and a 2082 and made a 982d and used a cv style shaft had to 2 peice it with a sleeve but works great so far... Sam sent me a drawing of the driveshaft adaptor and had one made. no pics of it rite now but can get you some next week
#26
the adaptor looks like this
#27
Sounds like a good long term solution. Yes I would like to see those pics.
#28
Here's a link on Youtube I found a couple years ago when surfing. The 782D's owner added the CV driveshaft to his tractor as well as power steering. If you check his other vids, he has one with it running as well IIRC.
http://www.youtube.com/watch?v=Gybtv8tQ1JI
#29
782D CV style drive shaft
Just a couple of photo's of a cv drive shaft I put in my 782D.
Sam Mac had the adapters for the engine and the pin style transmission shaft. Had to have the drive shaft cut and welded back together to fit in the shorter 78d frame. Works great but still have the old spring pin to hold the adapter to the trans shaft. That would be my weak point. Joe |
#30
Joe
Do you have pics of the shaft itself? I'd like to see what you did in the area where you shortened it. Thinking about the pump adapter, if I do any more of them I'm going to drill + tap them 90degrees from the spirol pin for 2 set screws just for some extra grip on the pump shaft.
