#21
Wow, That thing is working great. I have a question, How do I know if this will fit on my pressure washer.... Also how many GPM/PSI is your pressure washer?
- Cory Sanderson -~~- Cub Cadet 104 -~~- Cub Cadet 104 -~~- Cub Original -~~- Cub Lo-Boy 154 -~~- |
#22
My pressure washer is a 3GPM 3000PSI Northstar/ Northern Tool. The sand blaster calls for 3 - 8GPM at 1500 - 3000PSI. I changed the fittings on the sandblaster to get it closer to the trigger, it came with a 2' or so long wand and I wanted it closer for better control. Just 1/4" pipe fittings. You can check it out on the Northern Tool web site, it's item number 2260
#23
Sam how well do you think this type blaster would work on heavy rust , like a truck frame .
#24
I think it would do the job, it is not as fast as a big air powered blaster and it is a bit hard on the nozzles. I have used up two of them so far. If you buy one get a couple spare nozzles at the same time.
