Old 05-20-2011, 11:46 AM
juniors1282's Avatar
Send me a PM I have what you need.
1966 IH cub cadet 102x2
Old 05-20-2011, 01:41 PM
inspectorudy's Avatar
Default aluminum rear warning
Thanks for the warning. I ordered a bracket from Extreme motors that has two extra bolt holes that go around the axel housing and uses two of those bolts which are 90 degrees to the tranny cover. I will not be pulling that much stuff anyway. I appreciate how everyone chimes in with their knowledge to help the other members. I guess if you own a CC you are already in a special group!
1811 Hydro
Old 05-23-2011, 06:22 PM
Default Hooray!
I finally got the correct lift arm today from juniors1282 (Eric) in the mail and it fit perfectly. Other than the red color it was perfect . I hooked it up to the three point hitch and tried it out. Man that thing is strong! I weigh about 240 and with me sitting on it it didn't even strain. Extreme is making me a lift and as soon as I get I will send pictures. My back feels better already!
1811 Hydro
Old 05-23-2011, 06:34 PM
mmzullo mmzullo is offline
The back of my 1811 is different that the picture you posted. I think there was a production cut of when the frames where made. I had to weld plates where you bolted the franteistien bolts. Yours was easy. I made the lower bracket like extreme works. I've had my lift on for about 4 years. That was before he started to produce his. He does make a great product. I have pictures on my laptop and not on this cp.
Old 05-23-2011, 09:27 PM
Default Your back end
I would love to see the later backend of your tractor. I can't imagine saving that much money by eliminating the two side plates. Of course the big three wasted years by not using stainless steel bolts and screws when they could have to save a handful of coins. The bean counters in a big company have the final say on the bottom line and when they see a few dollars in savings they take it no matter the loss of reputation.
1811 Hydro
