Old 05-21-2011, 12:56 AM
squatch squatch is offline
Figured I'd post up some pics.
Adjustable on the left Walbro on the right.
You can see the adjustable main jet on top.
Clean parts.
Where it belongs.
Old 12-06-2016, 12:35 PM
Howdy folks, I haven't been on the forum in a while. The Rat Rod Super has been working like a champ. Maybe too much so. I was getting lazy about using the fuel shutoff I installed.
Came out a couple of days ago to start the tractor to mulch some leaves before removing the deck for winter. I saw a drip of oil under the front. I did a oil level check and found the crank case full of fuel again. It's been a good while since this last happened. Not sure if it's the fuel pump leaking or if the rubber tip on the float valve is ate up by alcohol again.
I check and probably change out both. Just thought I'd post this thread back up as a reminder for folks. E10 fuel does a number on both the fuel pump and the float valve rubber tip.
I just hope I caught it before blowing a main seal again!
I'll post up what I find.
Old 12-06-2016, 12:42 PM
Has nothing to do with the fuel. We have to tell people this all the time it seems. I should remind you, that you should always check the oil in your tractor before you start it. Don't rely on floor puddles to indicate a need to pull the dipstick.
Old 12-06-2016, 12:56 PM
I do check it regularly but not everytime. It burns so little oil I normally don't need to check the oil everytime I use it or even very often.
Old 12-06-2016, 01:21 PM
Terry C's Avatar
Terry C Terry C is offline
When I shut the tractor off I take the key out and put it on the battery. This prevents the kids from messing with it and since I have to open the hood to get the key,I check the oil.
Older ones I put the key on the tank.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 12-13-2016, 06:22 PM
New float valve and fuel pump installed. some cleaning and I'm back in business.
