Old 06-21-2011, 07:21 PM
Mooner's Avatar
Mooner Mooner is offline
It should work very well, at that setting. Can't wait to see your pics.
OK, here it is. It worked great. Something I noticed .... as I made sharp turns the wheels stutter a bit. Not bad, and it goes back to normal when it straightens up. Is that normal? The dump feature is great, too.
Old 06-21-2011, 07:35 PM
Sounds like you got the brush turned backwards.....
Old 06-21-2011, 08:15 PM
Mooner's Avatar
Funny guy! Do you remove the grass catcher when you store it? It sure would take up less room that way.
Old 06-21-2011, 08:25 PM
Yep, set the base up on its end and hang the top of the catcher in the hitch end.
Old 06-21-2011, 08:36 PM
Mooner's Avatar
Good plan! I'll do that tomorrow. I have lots of work to do in the back 40.
Old 06-21-2011, 09:28 PM
Mooner
Looks great hooked behind your Cub.
Old 06-21-2011, 10:31 PM
Mooner's Avatar
Mooner
Thanks, Diz. I'm having fun with the Cubs and learning lots, thanks to most of you here.
Old 06-21-2011, 10:48 PM
Nice cub and sweeper, Mooner!
Old 06-25-2011, 10:07 PM
Mooner's Avatar
I discovered today, after using the sweeper, that I can flip the catcher up and it will rest on the sweeper portion. It takes up lots less floor space that way, so I may just store it in that fashion. When I'm finished for the season, I'll disconnect the catcher and hang it in the barn and stand the sweeper up on end.
