Old 07-23-2011, 09:46 PM
I think the brake rockshaft needs to come out, but I can't remember. Replace the brake puck o-ring while you are in there if you haven't.
Old 07-23-2011, 11:02 PM
TEET's Avatar
TEET TEET is offline
I'm with Matt, Kelly. I'm pretty sure in order to access the bottom of the pump bolts the brake linkage must come off, its not too hard especially considering I just had it off of that 682..hehe! I also replaced the brake puck o-ring...Matt was nice enough to send me a few a while back, so you should be good there
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 07-26-2011, 12:37 PM
cubs-n-bxrs's Avatar
Well narrowing in on the final stages of the repowering of the 682. The engine is in and bolted down, driveshaft done, hydraulics installed and the ported pump installed. Now on to the wiring and exhaust modification. Want to keep it on the quieter side. Hopefully Saturday morning will be her maiden voyage.
Old 07-26-2011, 12:41 PM
Pics I forgot to add
Old 07-26-2011, 12:47 PM
JOHN SCHUTTE's Avatar
JOHN SCHUTTE JOHN SCHUTTE is offline
Thats a beast of a motor! Looking foward to the maiden voyage!
Nemesis
Old 07-26-2011, 01:00 PM
Looking good, Kelly!
Old 07-30-2011, 07:21 PM
Progress finally and we got her fired up today. Sounds really tough with out a muffler on it. Wiring is all done and works like a dream. I reused the wiring harness from the 2185 and all the wires that had to be extended extended or shortened were soldered and covered with heavy wall shrink tubing. Added a couple indicator lights in the dash. One for low oil and the other is a charge indicator light. Also added a functional oil pressure gauge that will be light when the headlights are on. Next on to the muffler. Motor runs at 40lbs oil pressure warm at idle. Couple pics of my progress.
Old 07-30-2011, 07:25 PM
That's awesome, Kelly! Thanks for the update!
Old 07-30-2011, 07:43 PM
Awesome work. I do like being able to see my oil pressure too. It likes to be @40 psi also.
Old 07-30-2011, 09:25 PM
TEET's Avatar
Looks awesome Kelly! Great work on the oil pressure gauge and indicator lights, looks fantastic!! I see you mounted the lift cam too, did you weld a nut on the inside of the frame for it?? Keep us posted on your progress, Id love to do the same swap with my 1211 someday
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
