Old 11-15-2011, 08:45 PM
mrcubcadet's Avatar
Nice work, Adam!
Looks great!
-105___ Tiller
Old 11-15-2011, 09:04 PM
LarryW's Avatar
LarryW LarryW is offline
Thumbs up
Looking good. Thanks for update!
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 11-15-2011, 09:09 PM
Donovan M.'s Avatar
nice work adam
Donovan:
62' Original-fenders
Old 11-15-2011, 10:11 PM
That's great! Thanks for the progress update.
Old 11-22-2011, 07:39 PM
IHinIN IHinIN is offline
Got some more work done over the last 2 days. I still need to figure out how I want to make the hinge and where it will pivot. The tires are just for mock-up purposes. I'm going to buy 4 ply turf tires for it. This thing is going to be heavy. I'm guessing 200-300 lbs empty. On to the pics.
Old 11-22-2011, 08:07 PM
Since it is hydraulic, LOW is your friend!!
They only need to be high if you make it hand dump.
Put the hinge as far back as possible, and make the bed as low as possible. IMHO
Old 11-22-2011, 08:08 PM
cub123's Avatar
cub123 cub123 is offline
Looking good , what you going to haul in that thing, lead?
Old 11-22-2011, 08:31 PM
The hinge is going to be around 12" from the back. According to my rough calculations, in order for the bed to tilt 45* with an 8" stroke cylinder, the cylinder needs to attach to the bed 10" in front of the pivot. That puts the cylinder rod attached at 22" from the back. If I move the pivot back farther, then the cylinder needs moved back as well to maintain a 45* tilt.
Old 11-22-2011, 08:36 PM
LarryW's Avatar
Looks like it should survive going through a battle zone, lol. Looking great! As far as your lift thing is going, what about using a scissor type joint in there? It would be a little more difficult to build though.
Cub Cadet 1811
Old 11-22-2011, 08:44 PM
Thanks Larry. It is a little overbuilt but hey, the steel was free. Besides, it should live as long as a Cub this way.
I'd thought about a scissor type lift but I'll try the cylinder as-is and see how it works.
