Old 11-08-2011, 05:35 PM
If there is room for two seals, and they could (should) be on the suction side, maybe you should only reverse one of them.
Then you are covered both ways.
Old 11-08-2011, 05:51 PM
One other thought before you put the pump back together.
I had a friend that cut the end of an engine shaft to shorten it.
He did not get it straight, the engine had a bushing, not a bearing on the output.
The seal leaked. The mfgr said it was due to the out of balance shaft caused by the angle cut. He cut the shaft straight, the seal stopped leaking.
There is a lot of material ground off one side of the shaft. Could it be out of balance!!?? Put that shaft in a 2500rpm hand drill and spin it, you will feel a lot of out of balance vibration.
Just something to think about as those pumps have very little bearing area and spread.
Old 11-21-2011, 12:19 PM
rhampshire rhampshire is offline
Well guys, after much effort I finally got it licked. Here are the steps I took:
1) Take pump apart and reverse the outer seal. Still leaks, but not as bad.
2) Take pump apart again and reverse the inner seal. Front shaft is not leaking - yay! But after having this thing apart so many times the seal at the back of the reservoir started leaking. Grrrr...
3) Go to auto parts store and pick up some rubber/steel drain plug washers. Take pump apart again and find out they're too big (I got the smallest ones they had). Say screw it and slap some permatex on the old washer and stick it back together.
It worked! Finally, NO LEAKS!
Old 11-21-2011, 01:06 PM
Glad you got it fixed!
Old 11-22-2011, 09:18 AM
mmzullo mmzullo is offline
Glad to here it's not leaking.
Old 11-22-2011, 11:28 AM
Same here! You've had a time with this lift!
