Old 01-20-2012, 03:58 PM
yesmar74's Avatar
yesmar74 yesmar74 is offline
Default WWF
The way I do it on tubeless tires is to lay the tire and rim flat on the floor with the valve stem were you break the bead in a small spot and pour it in.( Slowly ) As the tire fills you can slowly lift the stem side up and pour till no more will go in. I can get almost 9 gallons in 23x10.50s. The total weight in each is right at 90 pounds in Carlisle True Trac. Air it up and install. It is a huge help but for snow narrow tires with chains are best.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
Old 01-20-2012, 05:36 PM
krhoover krhoover is offline
I used the tool that attatches to the valve stem with a bleeder valve and then to a garden hose fitting. I had a drill pump that I put the other end into a 5 gal bucket. It wasn't the fastest but wasn't all that bad. Got the valve stem adaptor at TSC for around $10.00. They had WWF on sale for $1.50 per gal, but don't know about now.
Old 01-20-2012, 06:16 PM
ndanger ndanger is offline
More than one way to skin a cat. Thanks for the suggestions and tips.
Cheers,
Dave
1976 1250 Quiet Line/44" Mower Deck
1976 1650 Quiet Line/50" Mower Deck/42" IH Blade
Agri-Fab Utility Cart
Old 01-21-2012, 12:07 AM
johncub7172's Avatar
I keep the throttel and choke cables lubed with WD-40 at all times druing the snow season.
Old 01-21-2012, 09:19 PM
Dave01's Avatar
Dave01 Dave01 is offline
Originally Posted by krhoover View Post
A little update on snow plowing with my 1450. I filled the tires with WWF. I got 61/2 gal in each wheel. It made a big difference on how much better the traction was. Have used it twice since doing it. We got another 5" today and had no trouble at all. Now when I go thru the yard to the the dog kennels, if I don't pay attention, I doze the ground, where before I would just stop and spin. I have also made a bracket with a 1" allthread (like one I saw on here) to put another 50lbs of barbell weights or so on each wheel. Hope to get that set up this weekend. Thanks to all for the ideas I get off of here.
So it sounds like you got about 50 lbs. in each tire, now you are adding another 50 lbs. to each. That will make a huge difference, maybe even try that before changing out the tires. You mentioned the ground was soft so I wonder if you're better off with the tires you have.
If you can add another 100 lbs. on your rear hitch you'll go through almost anything!
1864 w/48" deck, 2084 w/54" deck + 54" blade, 3204 w/48" deck
Old 01-22-2012, 10:46 AM
Thats what I'm hoping for.
