Old 03-10-2022, 07:51 AM
Good grief!!
What an abortion!!
Old 03-10-2022, 09:15 AM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
Originally Posted by the_city_redneck View Post
The more I look at the pics side by side, I think it is the same tractor. The diamond plate on the front looks too irregular and similar to be two different cubs. Who would have thought a quick google search would have led me here haha
I think that's a safe bet. Decals on the sides of the fiberglass dash, one side faded off and the other side isn't. Tires are all the same tread (chains have since been added). In the OP's pics from 2012 the tractor is clearly missing a hood and upper grille/headlight bezel, and in these new pics we can see that someone had since cobbled together mounts for a 1X4 1X5 series hood.
Also looks like they removed the damaged fenders and replaced them with the fenders from probably the same 1X4 1X5 series tractor that the hood came from. Replaced the seat as well. Oh, and the hydro lift musta stopped working so someone tacked on that manual lift.
If I were you I'd remove the cobble job hood and bezel and search for a correct one, as well as the correct set of fenders. Get the hydro lift working again as well. parts tractors aren't too difficult to locate. With some work I think this could be a nice really unique tractor. Don't forget to replace the engine isolator mounts.
I decided to decode your serial tag too, you have a 1250 (0630) built in August 1977.
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 03-10-2022, 03:55 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Might very well be the same tractor......The original poster is also from NJ!
Plow blade
#2 Cart
QA36 snowthower
Old 03-11-2022, 10:56 PM
the_city_redneck the_city_redneck is offline
Thanks Cub Cadet 107, I appreciate everyone's advice. Unfortunately this one is on the bottom of the restore list. I got a 86, 76, 105, 125, 127, 147, 149 all ahead of it
Old 03-12-2022, 09:31 AM
Farmall450's Avatar
That poor tractor has been through a lot in the last decade. Ironic that you found the same one, would be cool if the OP chimed in with who/when he sold it.
