Old 02-20-2012, 09:52 PM
OK, you will pull the lever down far enough to rotate the lever holder up and over it. Once the holder is over top of the lever let the lever rest up against the holder. This is what holds it so you can push it around.
Old 02-20-2012, 11:28 PM
cmatthew's Avatar
cmatthew cmatthew is offline
thats what i thought. it will bend tha tab back to where it belongs. thanx dx3
Old 02-21-2012, 08:09 AM
gcbailey's Avatar
gcbailey gcbailey is offline
if you look in my pics, you can see where I switched out my manual valves to the auto release ones. My "flapper" was broke off, and I got a lucky buy on ebay on a set. Something you may want to consider.
Gary
Old 02-21-2012, 12:31 PM
I also switched to the auto release valves, when I had my 1250.
Old 02-23-2012, 10:10 AM
Good pics! If you want to switch out to the automatic type check out the link from the tech section of the site. The price has gone up a little but it's still cheaper then any others I've seen for sale.
http://www.onlycubcadets.net/forum/showthread.php?t=3
Old 02-25-2012, 12:16 PM
cmatthew's Avatar
i would start with pulling off the fenders and seat. checking the trunion and underneath at the linkages from the control lever to the trunion. if the control lever is moving the trunion back and forth like it should then its time to dive in a lil deeper.
Old 02-25-2012, 12:20 PM
cmatthew's Avatar
also wanted to let you guys know i had gotten the trunion slots welded up and springs replaced. the hydro fluid and filter replaced. now this baby has got some snap too her. and no more accelerating or deccelerating up or down hills. thanx everyone for the advice.
Old 02-25-2012, 12:24 PM
Originally Posted by bob o View Post
My 123 suddenly stoped working. The control lever seems to move a little easier but nothing no forward or reverse. No sound of the hydro wine. This tractor does have fluid up to the fill hole. I'm hoping that some linkage came loose and not a junk hydro unit. I would appriciate any Ideas.
Bob O
Bob it would be best to start your own thread so we can keep your 123 problems in there own place.
