#21
MattG,
Patton Acres aka quietline has one on ebay item number 230746395824 right now for $220 plus shipping and I figured with them being a sponsor they would have good parts that's what I used for a reference price. Welders around here will charge me a flat hour even if it only takes 5 minutes and that will be $50 or more depending on their mood. I may just pull it and bite the $$ bullet anyways and be done with it. I'm in no hurry to get it back together so I may tear it completely down and just start a rebuild. What other issues do you know about this particular model I should check?
Don Smith https://www.facebook.com/SouthernKentuckyCubCadetClub IH 982D aka "The Big Red Smoker" BRS w/3pt hitch CC 1572 aka "The Big Yellow Smoker" BYS w/3pt hitch-PTO Brinly Cat 0 3pt plow-Brinly sleeve hitch plow Custom Hydraulic lift disc-Haban Blade-Brinly Cultivators Cub Cadet lawn trailer and lawn sweeper |
#22
Congrats on the new Super! Check for worn bushing and tie rod ends in the front end. I replaced my bushings and replaced the tie rods with Rod ends. There's a write up around here somewhere. Same with front wheel bearings. Check out the lift arm and make sure it's not cracked. Also check the gap on the PTO and look for overheating in the wiring connectors on the left side relay for the PTO and the ignition switch. Pull the starter and go through it per Matt's write up on here. The biggest issue may be the Walbro carb throw it away and replace it with a rebuildable and adjustable carb off a KT17. I also have a thread on that. Check my profile. If you need picture references feel free to browse this album. Pics of everything I've done to my 1872. Down to frame and back a few times.
http://s172.photobucket.com/albums/w...cpZZ1QQtppZZ16 |
#23
Nice super you'll have it fixed up in no time!!
Dale 147-Restored___________________882 Diesel Hydro lift (not installed)___________44" Deck 48" Deck_______________________QA-42a/b Snowthrower Rear lift ________________________XMW cat-0 rear lift Model 2 tiller____________________12" cat-0 Brinly plow |
#24
Congrats on the 2072 and parts tractor!
#25
You can also use the rear housing from the parts tractor. You must change the gear reduction gears they are different. Just find you a hydro from a 149 and use the cast iron case you will still need to change all the internals but it will never fail again.just some more ideas for you. If you were closer i a good case one of each cast or al. Just trying to help out joe
#26
Here's the plan so far DX3 is coming down Saturday with a welder to remove the bolts. After all the suggestions I may try to find a cast case and do a switch out over the winter. Is the switch out something that an average mechanically ability with average tools can do?
#27
You should be able to do it. The gear reduction housing will have to come off and the gears changed.matt may have a write up on this if not vince o. Just done one and he may chime in on this it should be a straight forward change out. The reduction gears are diff. For the regearing for the 26 12 12 tires but you should be able to do it. Just keep the parts separate you also can take pics. For reference if you have ? You can look at them. Just trying to help joe
#28
The only 'special' tool I can think of at the moment that you'll really need is a dial indicator and magnetic base to set the backlash, but even a cheap Harbor Freight one will do.
#29
Matt does have a write-up on this. It's pretty good. Led me straight through it.
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
#30
Its been a long week, having a brain fart. Correct transmission fluid part number for the 2072 is 737-3062? Tired of searching and only find the hytrans debate threads
