#21
That's awesome, Jeff! Congrats!
#22
Thanks. Can't wait to get it home.
#23
I need to upgrade my lathe!
I have an identical Mill/Drill made by ENCO, but you've got me beat with tooling ![]() Does this mean we can expect billet aluminum under-drive Cub deck pulleys and lightweight engine blocks? ![]() btw: Are you still making brinly hitches and those tiller extensions? I'm in need of both
----------------------------------- 106 Needs a clutch-------107 (Lent to my brother) 123 w/hydro lift & qa36--126 w/creeper and lift 127 restored--------------129 50" mowin machine 129 w/hydro lift-----------147 plow horse w/tiller 149 auction score---------782 KT17SII |
#24
10" four jaw chuck for the Monarch
#26
Excellent work, as always, Jeff!
#27
Excellent choice in lathes, Jeff. I believe that's a CK-series. I've got a 10EE, and it's the sweetest machine on the planet. What I can't cut with it, I cut with a 24x210 Lodge and Shipley... which isn't quite as precise as the 10EE, but it does the trick.
Did someone say drill press? It's a Johannsen radial, fitted with a Bridgeport BRJ head, but using a 2hp Baldor 3-phase motor, driving the spindle with a Carlisle RPP toothed-belt setup in 3:1 reduction. Motor is driven by an Allen-Bradley 1305 type AA12A variable-frequency drive, fed by a 240v single-phase 15A receptacle. Full speed control from stopped spindle to just under 2000rpm (motor's spinning at about 6000rpm)... and I've equipped the drive with additional braking resistors for dynamic braking... when you stop the spindle, it stops NOW! Motor's mechanical fan has been removed, and replaced with a 240v computer-type 'muffin' fan, so it's whisper quiet, even when drilling a BIG hole. I've also fitted the table with an electric gearmotor for changing table elevation. Also have a footpedal with two-stage control for power-tapping, and a pair of LED floodlamps that power up anytime the controls are on. |
#28
Latest addition to my home shop, a Racine power hacksaw. I need to locate an electric motor for it but other than that, it's ready to go
![]() ![]() ![]() That's a yardstick on it. There is a whole lot of cast iron there, it must weigh well in excess of 300 lbs
#29
That's cool Jeff!
![]() Predecessor to the bandsaw! |
#30
nothing like having your own tools.looks like you have quite a few toys to pay with.
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀. |
