Old 03-30-2012, 12:11 PM
I got to look them over at RNPD, nice set of tractors! The early 61 with the thin axle was in sweet shape! Course I liked the other one with the rear PTO too
I thought I saw your finger prints on them! Lots of work to do to them but looking forward to the ride.
Good luck on the O's, Duke.
Thanks Allen! I might need someone to help me test drive them when I'm done. Evan's not a fan of the gear drives so got to find someone else to help me drive them when they are done.
Old 03-30-2012, 12:12 PM
I think, I can help you out.
Old 03-30-2012, 12:15 PM
I think you'd not need to remove any material. At the risk of violating the Correct Police :-) , a small clearance hole to provide say a #10 machine screw which would hold a rubber donut parallel to the tab you have highlighted to keep the hood from rattling and scratching away the inside of your pretty new hood. Leaving it a little loose allows the rubber donut to move a bit but dampen the hood rattle.
My .02
John
PS: Glad to share what little I know about the trans stuff...it isn't much but I haven't broken anything yet! :-)
I don't think it will be much removal but I'm thinking of trimming them done a little and using the coating to protect from any vibration damage. I'm sure someone else has run into this same problem.
It'll be nice to have someone to talk to while I'm going thru it. I'm not worried about taking it apart it's the putting in back together is always the hard part.
Old 03-30-2012, 12:28 PM
Sweet!
Old 03-30-2012, 12:40 PM
I've been called a stirring stick a few times before. LOL
Old 03-30-2012, 05:09 PM
Looking forward to the read, and PICTURES of your progress Duke
Old 03-30-2012, 06:52 PM
EricR's Avatar
EricR EricR is offline
Good luck on them two Duke, Oh and by the way good luck were all counting on you.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 03-30-2012, 07:45 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default ...and...
did we mention pictures?
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 03-30-2012, 09:18 PM
ROFL!
I'm looking forward to getting some pics of these projects!
Eric, so much pressure!
John
John what no
Old 03-31-2012, 12:51 PM
Got both in the garage last night. Got the 5 digit set up to test the engine. Not starting but it has spark and fuel so going to check timing and make sure that is set.
Once I get it running it's time to start breaking them down for powder coating.
