Old 05-05-2012, 02:15 PM
jdroison jdroison is offline
Default lead
the lead in the gas did act as a lube on the valve guides, like in the IHC regular which ran on kero originally. the valve guides needed a mod when going to unleaded.
Old 05-05-2012, 02:23 PM
Merk Merk is offline
by Wild Bill
So to say that these old engines were puposely designed to burn a fuel that was not in use at the time, is asinine.
I suggest you read the section on fuel types. It can be found on page 1.5.
It has a section that talks about leaded gas can be used in areas where unleaded gas is not available. Including the internet manual I have 4 sources for a Kohler Service manual. All have the same date I posted in a previous post.
This is 2012.....not the 60s, 70s, or 80s. I have go by what the Kohler manuals say. Unleaded gas was available in the early 70s in my area. It cost more.
Like you I ran unleaded fuel in my small engines until it became unavailable. One thing I notice is I have less valve problems with unleaded fuel.
Old 05-05-2012, 04:44 PM
jcsmith jcsmith is offline
Default sticking valve
I 2nd Sam Mac. My 104 did the same thing. The fins on the exhaust side of motor were packed with grass and dirt, leading to too much heat and stuck valve. Good luck, Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 05-07-2012, 03:44 PM
TONYD TONYD is offline
THANKS to everyone. the Additive you recomended seems to be helping I use the mower today for about 3 hours and I was on a steep incline with heavy grass before it did it. I hope it gets even better as I keep using it.
Old 05-20-2012, 08:42 AM
orphie orphie is offline
CADplan:
Per your advice, went ahead and pulled the engine on my 1872, for the replacement of the iginition module. Went well and while opened up, cleaned and replaced a couple missing bolts as well as the fuse holder, which was causing some issues. Photo taken while "work in progress".
Old 05-20-2012, 09:04 AM
Please tell me there's something holding the engine securely in that position...it looks pretty precarious.
Old 05-20-2012, 10:38 AM
fixerlr's Avatar
fixerlr fixerlr is offline
I use nothing but 91 oct fuel onall my small engines it doesnt have alcohol in it and has a longer shelf life works for me
123 hydro lift
100 ceeper
#1 tiller
109 w/16hp briggs?
front plow
snow blower
40 inch deck
oh I forgot a green 317
Old 05-20-2012, 01:13 PM
by fixerlr
You need to to go to your Kohler Service manual and read/reread the section I listed in my last post. 91 octane fuel has no longer self life that E10 fuel. Mosy if not all small motor manufactures recomend buying fresh fuel every 30 days and use a fuel stablizer. Where you store, how you store and the container you store your fuel in makes a huge difference on fuel quality. I haven't found a stock Kohler engine that needs 91 octane fuel to run right.
Old 05-20-2012, 01:33 PM
I agree that 91 is not needed, but, if 87 has ethanol, and 91 doesn't,
I would run the 91!!
I have seen many places that only sell a certain octane as no ethanol, luckily around here it is 87.
We have one station that sells 87 with ethanol and 87 without ethanol.
Decisions, decisions!!
Old 05-20-2012, 03:02 PM
by CADplans
I don't have problems running fuel with ethanol in it. Most of the time people having fuel issues goes back fuel storage problems.
