Old 10-07-2009, 05:32 PM
Very very nice work. I would like to do the same thing on my 149, only a dual brake. You have given me a nice guide to start with.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 10-12-2009, 05:15 AM
IHinIN IHinIN is offline
Well, I got it back together and running yesterday. The new brake pedal works great. I still need to figure out a parking brake for it. While I had it apart I spray bombed a few things like the wheels and the grill mesh since they were covered in surface rust. I also painted the gas tank and made a new set of stainless straps. The old straps are too long since the tank on it is obviously for a 70 and the straps were for the bigger 100 tank. I'm now working on making a mounted salt spreader out of a tow behind broadcast fertilizer spreader.
Old 10-12-2009, 12:48 PM
IHinIN,
Your 100 looks great! I really like your brake pedal. I've really enjoyed your pics of progress!
Old 10-12-2009, 10:01 PM
Thanks ACecil.
Old 10-19-2013, 05:32 PM
Well, it only took me 4 years to get this project done. Today, I finally made a parking brake latch. I built it similar to the old Farmall setup with a ratchet plate and a catch on the pedal. The Farmalls had the notches on the pedal and a spring loaded catch hooked to a handle to set the brake. Stomp on the pedal and the catch releases. Now I no longer have to shut off the tractor in gear to keep it from rolling downhill.
Old 10-19-2013, 05:46 PM
EricR's Avatar
EricR EricR is offline
Great job Adam.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 10-19-2013, 07:07 PM
Nice job Adam!
Old 10-19-2013, 10:11 PM
Top notch job, Adam!
Old 10-19-2013, 11:06 PM
fourinchdragslicks fourinchdragslicks is offline
Very Nice!
Old 10-20-2013, 09:30 AM
Maple Cabin's Avatar
Maple Cabin Maple Cabin is offline
Default No offset
Where did the offset pedal go. I don't see the lift handle ether.
I do see that you have a different lifting attachment. So does the lift rod for the front attachments run on the outside of the brake pedal now?
Doug
126 Creeper,H lift,Deck, Sleeve hitch, B Plow, Weights
129 Deck, Blade, Weights
1200 Creeper Deck: 1250 B Tiller odd deck
782R with power steering
JD 110H:JD 112H
