#21
(note the wood splitting wedge is removable/exchangeable and is on the ground) The two flat areas just squeezes the tire to break the bead off the rim. The rim is above the flat surface plate. Here it is as a woodsplitter.
#22
Well,I got the V61s mounted on my rims!
Not sure how much air pressure to use. I put 20 psi in the tubes. Any suggestions? Waiting for my new wheel bearings to arrive, then I'll get the wheels back on the 1250. By the way, I used this tire changer from HF. It worked great! Can't wait to get them on the tractor! I'm happy!
#23
The tire pressure should be listed on the side wall of the tire. I just ordered a set of these for one of my new toys too! I opted to get the free shipping to a local tractor show, but thats 1 month away so the wait is killing me. Yours are looking good though!
David in NC Wanted to buy Category 0 attachments and 2000 rpm implements
#24
Can't find any mention of tire pressure on tire sidewalls. That's why I'm asking.
#25
Max is 28 PSI with max load of 620 lbs. per tire
#26
Thanks, I should be safe at 20# then and can adjust it as needed. But I won't go over 28#!
#27
the manuel says 6-8 pounds but my tri ribs have 18psi in them
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10:
#28
Those V61's are looking good!
#29
Nice tires and rims.How much was the tire changer?
Up to 534 and counting... I give up updating my profile! |
#30
The tire changer was on sale for $39.99. Not real heavy duty and some have said they broke theirs right away, but just use common sense. When breaking a bead, keep turning the tire and push, turn and push, you get the idea. Once it gets to a certain spot, it pops the bead. It worked great. I was well pleased.
