Old 07-10-2012, 05:34 PM
Well I guess I'm going blind but I do know what a Hiem joint looks like, had 6 of them on this.
Old 07-10-2012, 08:55 PM
John147 John147 is offline
Okay here's is another question to make sure i have my box right. I know the ross steering box is a 2 turn box i had assumed thst this meant from center that it takes one turn to the left to hit lock and one to the right to hit lock. While reading on another forum is said it should be 2 turned in each direction to hit lock to lock. Is what i am thinking right or wrong?
Old 07-10-2012, 10:39 PM
The drag link isn't supposed to be bent...the ones you're seeing on epay are all messed up. The steering box is 2 turns lock to lock. Whoever told you two in each direction was wrong.
Old 07-11-2012, 08:02 PM
Vince_o Vince_o is offline
Sam
Ill trade you Volvo and 2 kids for that! Pm me!
I think Im with Kev and Matt, a little of both, definatly NOT the right set up for the 147.
Old 07-11-2012, 08:10 PM
Originally Posted by Vince_o View Post
Sam
Vince
If you put that in a Cub you just may want to beef it up, just a little.
Old 07-12-2012, 07:59 PM
jcsmith jcsmith is offline
Default drag link length
John147, On my 104 the drag link measures 15 9/16 " end to end, and the tie rod is 17 3/8 " . Hope this helps, Chris . Measured without ball joints.
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 07-13-2012, 10:15 AM
dbuck dbuck is offline
Okay fellows, just measured mine. 127, 17 1/2" Joint end to joint end. 149, 16 1/2" joint end to joint end.
Old 07-13-2012, 08:47 PM
Okay grabbed a new drag link and still 1 1/4 left and 3/4 right now i just need that quarter of a turn to mover right and i will be good.
Old 05-29-2013, 10:08 AM
CLE CUB CLE CUB is offline
Matt
Unless I'm going blind the second pic shows a rod end clevis connected to the steering box. My guess is it's binding and the drag link is probably the wrong length also.
These are definitely hiem joints. I ordered a set for my 108 from McMaster Carr. I replaced both the tie rod ends and drag link ends. They were about 3/8 inch longer that the stock 1's but the they work great and have grease fittings. Replacing them took a lot of play out of the steering. Gonna try and tighten up the pivot bolt today maybe. I can see it moving when i turn the wheel.
Here is the part number for McMaster Carr if anyone wants to try them out. They were $6.20 each.
PN: 4444T931
_____________________
Cub 108
Farmall Cub
Old 05-29-2013, 10:44 AM
PN: 4444T931
Cub 108
Farmall Cub
Welcome to OCC! Glad to have you!
