Old 07-06-2013, 07:00 AM
rweaver rweaver is offline
that's a nice job did you put a plate on the inside
Old 07-06-2013, 08:59 AM
Originally Posted by cjet69 View Post
Got the frame welded up. Just rattle canning for now because he wants to paint it soon. Also straightened the top of the frame where the grille mounts and now the side panels fit.
Great job on the frame repair!
Old 07-07-2013, 01:06 PM
Good job on the frame fix!
Old 07-07-2013, 07:42 PM
cjet69's Avatar
cjet69 cjet69 is offline
No I didn't put a plate on the inside. I ground a V in the frame and welded it up. I can see a bead on the inside so I know I got full penetration. If he has any more trouble with it then I may add a plate. The best time to do that is when he paints it and has the engine out.
CC 1450, 44A deck, #2 tiller, 42" plow/blade
CC 124
CC 1220
#2 Cart
Old 07-09-2013, 02:05 AM
cjet69's Avatar
Found a rattle can of Case IH 2150 and shot over the repair.
CC 124
CC 1220
#2 Cart
Old 07-09-2013, 06:22 AM
Looks great!
Old 07-09-2013, 11:27 AM
That looks awesome!
Old 07-13-2013, 01:37 AM
Acooper Acooper is offline
Talking
Originally Posted by ihc353s View Post
have the same Problem at my 123, that i purchased a few Weeks ago. After loosen the Screws of the Engine Oil Pan, the Front Axle falls down to the Ground, with the Bracket. Have a MIG/MAG Welder, but can't weld it, i have a Pacemaker, and i think it's to dangerous for me, i'm little angry. Tomorrow, a Friend will weld it for me, with my Welding Machine.
mfg Georg
I have a pace maker as well. Check with your mfg about the limits of welding.
You can not be life dependant on the pacemaker. IE it stops you die!
Mine lets me weld as long as i dont go over 130 amps. Wrap the ground around the positive lead a few times. Keep the weld point at 24 inch distance. Take frequent breaks.
