Old 02-03-2013, 02:46 PM
Ihquietline's Avatar
Ihquietline Ihquietline is offline
If you look at the pdf for either #1 or #2 it shows a belt guide that goes on the front of the transmission my guess it is for keeping the belt from slapping too much which could cause the belt to come off pulley on gear box. The guy I bought the tiller off of didn't have one he said he never used one, so my guess is it isn't that important. As long as the belt is good and tight probably don't have to worry about it. Hopefully somebody that knows for sure will post something on here.
Josh
1979 Ih Cub Cadet 1650,1987 Cub Cadet 1811, 1989 Cub Cadet 1772, 2006 Cub Cadet Z Force 50, 1A tiller with both extensions, Sears 10 in.moldboard plow, Ih 54 inch snow/dirt blade, Agri Fab 42 in.lawn sweeper
Old 02-04-2013, 12:34 AM
Yes, I've done it. Just bend them and be done with it. I added a second eye bolt in place of the spring, although I'm not sure it was needed...I don't use it on my 782D and the tensioner spring works fine and the belt doesn't slip, but that has a 5/8" belt, so...
Don't worry about the belt guard, either. I've never used one and not had any problems.
Old 02-04-2013, 06:53 PM
My opinion, the belt guide is needed. I've used my tiller quite a little bit and occasionally, the belt will jump off when the tiller hits some hard ground. I HAD a belt guide but I have not been able to find it and put it on. I also still have the tension spring for belt tension. Using the spring, it MIGHT cause more belt slap when working in hard dirt. NOT USING the spring might result in a broken belt.
My experience is using the smaller belt on a Quiet Line series.
