Old 03-07-2013, 10:56 AM
Congrats on the scores! Looks like the trailer did just fine.
Old 04-05-2013, 11:27 PM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
Well I just set the engine in the tractor and it should fit. Right now it is just sitting on the cross member and the jack. I will have to find a new place to mount the alternator it was sticking out to far it its original location. There is about 2 inchs between the engine and the hood at the closest spot so there should be enough space for the engine mounts. I need to know the distance from the flat of the flywheel to the axle cross member or some other reference point. I need to know this so I can get the engine in the proper location so the PTO will work.
Old 04-06-2013, 09:32 AM
The diesel looks good in the 682!
Old 04-06-2013, 10:29 PM
dale c. dale c. is offline
the 782d has the fuel tank under the seat to make room for the radiator
Old 04-06-2013, 11:35 PM
Mr.Goffena's Avatar
I know about the fuel tank I have not gotten around to finding one yet. One thing at a time. I have big plans for this guy I just want to get the engine in first. Then for the hydro lift I have been watching the post on the 3 spool hydro valve. But in order to do hydro lift I will have to get a ported pump. So the list of needed things goes on.
Old 06-03-2013, 11:25 PM
Mr.Goffena's Avatar
Sorry for the lack of posts on this project. I have however progressed some. I got a PTO for the diesel with the adapter plate. However it would not fit in the flywheel. My bother was able to get in on a lathe at his work and cut it out wider. I then drilled the five mounting holes and taped them. Here it is all mounted up.
Old 06-04-2013, 06:37 AM
Nice job!
Old 06-04-2013, 11:14 AM
Good job! Thanks for the update and pics.
Old 06-04-2013, 11:45 AM
seawalkersee seawalkersee is offline
I have an idea. Instead of scrapping the old engine, send it to me. That would be awesome.
SWS
Old 06-04-2013, 07:28 PM
Mr.Goffena's Avatar
SWS
Do you need a single cylinder KT17?
