Old 05-24-2013, 08:25 AM
Glad to hear you are up and running Bill!
Old 05-24-2013, 12:32 PM
Congrats on getting your 126 going, Bill!
Old 05-24-2013, 01:50 PM
what they said
Old 05-24-2013, 11:59 PM
IH Cub Cadet IH Cub Cadet is offline
More goings-on with the 126 today.
Found some screws to fasten the air filter face plate to the carb and finish off the air filter assembly install. Also finished bolting on the remainder of grill to frame bolts and installed the hood.
Put a new mule drive belt on and attached the deck, took a bit of time mowing some very thick, tall grass.
The only problem I had is the throttle wants to go down from full RPMs. Any ideas on how to tighten-up the throttle cable?
Thanks!
Bill
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 05-25-2013, 12:14 AM
The 126 is looking good!
Old 05-25-2013, 01:03 AM
Looks good all together Bill.
Does a nice job mowing too.
Old 05-28-2013, 11:22 AM
OK - the 126 is officially in service. I tightened up the throttle pivot and took the tractor to my Dad's camp where it will have mowing duties this summer.
I'm going to run it hard and see what I've got and from there decide what to do with the tractor. i.e. leave it like it is, do a full restore over the winter, etc.
One thing I am going to do is pull the 3 point hitch off my 122 and put on this tractor. That will come this winter.
Thanks!
Bill
IH Cub Cadet 109
IH Cub Cadet 149
IH Cub Cadet 1650
Old 05-28-2013, 11:39 AM
Great news Bill!
Old 05-28-2013, 12:14 PM
Thanks!
Bill
That's fantastic, Bill!
Old 09-16-2013, 06:42 PM
Been a while since I've posted an update on this tractor. I mowed most of the Summer with it and here are some observations:
48 inch deck give a pretty good cut. For whatever reason, I have gleaned from reading posts that the 44 and 50 inch decks do a better job. I've got a 44A deck on a 109, but IMHO, this 48 inch deck lays down a good cut. Spindles are noisy - that will be a winter project.
After a few weeks of use, the tractor would run and after an hour of hard use, would falter and stall. Finally it wouldn't start after cooling off at all. Checked the spark and didn't have any - so I replaced the condenser and got fire now.
Fuel bowl was full of crud. Cleaned it out and re-installed, but he rubber gasket/o-ring is hard and will need to replace as the fuel bowl leaks - won't run it this way. Wondering if I can replace the fuel bowl assy with a threaded hose nipple and just use an external fuel filter?
2nd gear mowing is FAST! Almost to fast. The tractor mows great at this speed (3.9 MPH), but the ride is very bumpy on this camp property and between my aching back and the danger of trimming obstacles, I don't think this is the gear for me and 1st is to slow. I've got two options, upgrade to a 128 (3.5 MPH) or a 582 (3.3 MPH) to slow things down. 1st gear is to slow.
I've got a front blade from a 122 - need to figure out if I can mount it to this tractor.
Other than that - very nice tractor.
IH Cub Cadet 109
IH Cub Cadet 149
IH Cub Cadet 1650
