#21
#22
Thanks for the update and your headed in the right direction.
#23
easter sunday all the kids in the family will be here with cameras will try to get some pic. i am going to day to get a complet 1450 i see where i will need some other parts from a complet tractor .mainly front brackets for front of hydro. also the rear i have at home now has internel brake .
#24
#26
diesel ring gear 46 tooth straight cut.
gas ring gear 40 tooth beveled diesel pinion gear 10 tooth strieght cut. gas pinion gear 10 tooth beveled cut. diesel reduction gear 68 tooth thicker gear gas reduction gear 66 tooth pinion to reduction gear shaft both 12 tooth diesel hydro pump out put shaft 10 tooth gas hydro pump out put shaft 12 tooth. the axles seem to be the same length diesel axles tubs have bearings in the end gas axles tubs have bushings diesel axles tubs thick on both side gas has one thick one thin well i really donot know how usefull all this info is. i do wounder wich would be geared higher gas or diesel rear.am i also going to have to have axles tubs bored out to fit bearings? |
#27
#28
how do you know how many shims to put behind pinion gear and how many behind axles diesel had three on pinion gear not for sure on axles i have not counted just took apart and keep shims with bearing caps layed out on work bench so i know where they came from i guss i am asking how do you shim up a rear end ,since this is a swap in to a different case .HELP the only thing i nevered work on is rear end gears.:
#29
You need to download the manual. It will tell you how to check. Matt G also had a good write-up on his site http://mgonitzke.net16.net/ look under 1872....hey where has Matt been?
#30
Mike, now that u r on the computer, get your kids to show u the site "u-tube " and search setting up rearend or shims in rear. should be a lot of stuff. Just guard the little ones eys as there can be inappropriate info as well. I too have never set up gears on a rear so good luck with all that. Dave
