Old 04-16-2014, 10:48 PM
jubilee's Avatar
jubilee jubilee is offline
Default Update on the D662 and 1482
I finally located a good used Kubota D662 head. From what I have been told, the D600/640 heads would not work on this engine. Bought it Monday morning and USPS delivered it today! After finding the cracks in the original head I pulled the pan and checked the rods. Found one bearing that was beginning to fail and replaced the rod. I need to collect or fabricate a few more parts-gas tank, fan assy, muffler and alternator before installing the engine in the 782. I am not in too much of a hurry since I now have the K321 in it. I just finished a re-do of the 44C mower deck. I sprayed it with Van Sickle International Off White 471 70 paint using a gravity feed gun. I am pleased with the color. The deck is on the tractor and waiting for me to apply the new decals. I purchased one new bearing assy and my machinist friend built a second new one similar to what some others have recently wondered about whether it could be done or not. I purchased a couple of NICE high load double sealed bearings from McMaster Carr and my friend made a new shaft to fit and a couple of sleeves to go over the bearings. So far it is working fine, but testing time has been very limited.
___________________
Jim
782 w/Command 18,
1862 not running;
IH 42 inch blade; off brand cart
Old 04-16-2014, 11:32 PM
Why did you replace the rod? What about the crank? What did it look like? Did you replace just one bearing?
Old 04-17-2014, 07:28 PM
jubilee's Avatar
A small piece of babbit was coming loose in the cap. The crank was fine.
___________________
Jim
782 w/Command 18,
1862 not running;
Old 04-17-2014, 07:29 PM
So, you only replaced one bearing?
Old 04-17-2014, 07:38 PM
jubilee's Avatar
Yes, the others were fine.
___________________
Jim
782 w/Command 18,
1862 not running;
Old 04-17-2014, 07:40 PM
Ok...... I wouldn't do that but it's your motor. If one was flaking, then the other are probably not far behind.
Old 04-17-2014, 10:53 PM
jubilee's Avatar
That is a possibility. After it has been run for a while I may pull the pan and check all of them again. It was only run briefly when I first got it so something else could show up when it is run for a longer period.
___________________
Jim
782 w/Command 18,
1862 not running;
