Old 06-18-2013, 10:40 AM
all4jpn all4jpn is offline
garbage can,...
multiple dollar store jugs of the "works" toilet bowl cleaner...
drop in...
pull out in a day or so..
hose off...
prime...
done
Old 06-18-2013, 01:39 PM
Originally Posted by Maxwelhse View Post
Wow..... That pressure washer sandblasting really looks like it's the ticket!
... are those 2 1" cylinders on that dumper? I think the bed needs bigger (3140lbs/ea @ 1000psi)!!!
Yeah.. That SOB even has the little 5 drawer side box for his tool box!!! I say we boycott Sam for having a better shop!!!
He's cheating!!!
Two 2" cylinders, just a little overkill LOL
The shop pic was my garage before I got the shop finished. This is Cub Ville.
Old 06-18-2013, 01:41 PM
Originally Posted by all4jpn View Post
garbage can,...
drop in...
hose off...
prime...
done
Love to see some pics. My problem is most of the stuff I'm working on won't fit in a garbage can, more like a small pool.
Old 06-18-2013, 02:07 PM
Old 06-18-2013, 04:36 PM
that would get expensive to fill...i just cleaned some parts yesterday..i'll find something rusy and show ya..works geat for a plastic contaier full of nuts and bolts too
Old 06-19-2013, 05:40 PM
jkier's Avatar
jkier jkier is offline
I've got an old 100lb pot blaster and a 351 Windsor powered air compressor.
I have to stand 10 feet away to do sheet metal
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 12-30-2014, 01:06 AM
a3v03v0's Avatar
a3v03v0 a3v03v0 is offline
Mine is a 55 gallon poly drum on a stand. There is a 14 inch square opening for glass and arm holes. A shop vac clears the dust. The last time I was at tractor supply I loaded up on media but so fzr havr only used sand. Whimpy compressor but ebough for the HF blasting gun.
Sometime i plan to try a DIY rig for soda blasting carbs,
I have been playing with electrolysis with washing soda on a small scale. It is now my favotite way to remove rust. It takes a lot longer but is very little work.
Then there is this setup, a lot of work to get from here from there.
