Old 05-09-2013, 12:06 AM
Lookin' good!!
Old 05-09-2013, 01:20 AM
Originally Posted by cuber View Post
I just replaced that exact same roll pin on my 1650 last weekend. I was able to remove a small piece from the top side and a small piece from the bottom, but then there was still a big piece stuck in the middle. So I ended up removing the right side foot rest and the outer rockshaft lift cam thingy which also had a broken roll pin. Then I sprayed a lot of PB Blaster on the rock shaft arm and was able to slide the big dowel out threw the right side of the frame just enough so I could swing a hammer and remove the rest of the roll pins that were stuck in the dowel. Hope this makes sense and helps you out... Oh and I also cursed a lot of swear/cuse words too, it didn't help much LOL
Forgot to mention I also removed the pin from the hydro cylinder and flipped that bracket up out of the way.
Thanks for the tips
Old 05-09-2013, 07:15 AM
Blade looks good mounted up Todd!
Old 05-09-2013, 07:54 AM
PaulS's Avatar
PaulS PaulS is offline
Amazing how mounting a blade can turn a cute cub into a mean mean earth/snow moving machine.
Old 05-09-2013, 01:57 PM
Oh yeah!
Old 05-09-2013, 08:59 PM
WooodyII2 WooodyII2 is offline
How much did you get the blade for Todd?
Cubcadet IH 1650 Hydrostatic
Old 05-09-2013, 10:47 PM
$100 with the hydraulic angle cylinder.
But I have to get hoses to see how (if) it (cylinder) works.
Old 05-10-2013, 09:04 PM
Sugarmaker's Avatar
Todd,
Big push blade looks really good on the tractor. I'm not sure what is broke but sure you will get it fixed
Its going to look good painted too.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 10-25-2013, 07:33 PM
Got back on the "face lift" of the push blade the other week.
So far I've got all the small things done, wire wheeled and primed and painted.
Next week I'll get the blade and mount sand blasted and ready for paint. Here's a couple pictures of the progress thus far.
Also I need to know something about the cylinder. It does have a small leak on the end, so.... Has anyone ever had one of these rebuilt? The packing needs to be replaced, so the end needs to be cut off and re-packed then welded back together. Has anyone done this, or had it done?
Thanks
Old 10-25-2013, 09:03 PM
Sugarmaker's Avatar
Todd,
The parts for the blade look like new. I'm not a cylinder guy. I would expect that these would be serviceable but I think you said it might not be??
A wood fire in the old wood stove feels real good, taking the chill off tonight.
Man you keep your shop way too clean
Regards,
Chris
