Old 02-11-2014, 11:32 AM
CTRUEX CTRUEX is offline
For rattle cans, I use Rustoleum's Ultra Cover 2x in Marigold, for the yellow. I'd say it's just a tad darker than the early yellow, but looks real close, and will match up good with a slightly faded later yellow. Plain Rustoleum in Canvas White is a close match to the early white, and their Almond White matches the later white on the red ones.
Old 02-11-2014, 12:55 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
I'll give those a try. I really like how the Rustoleum sprays.
I have a 100 that's darker yellow than anything I've sprayed out on test panels. I'm at a loss on that one. I just need to touch up a few spots.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 02-11-2014, 11:51 PM
inspectorudy's Avatar
I had a nasty run in with TCS over their Majik crap they call paint. I decided to repaint a John Deere with it using their JD green and it was so bad I had to remove all of it and respray it with real JD paint. I called the company and told them that on an 80 degree summer day the paint was forming little mounds instead of spreading out into a film and he had the balls to tell me to shake the can more. He also said he would send me some new nozzles for the remaining cans but of course he never did. I have redone 8 JD's and one CC and I can tell you that people who use after market paint really hurt the next guy who wants to repaint his tractor. If you use the factory brand then all you have to do to repaint is to sand and fill any holes. If you use Rustolem or Valspar, both good paints, then you have to do that and then use primer. That means an extra coat or two of finish paint because the primer will not be the correct color. I know the JD and CC paint is high but from someone who uses a lot of it to me it is worth every penny. Also, my JD dealer who is also the CC dealer will give me a 10% discount on the paint if I buy five or more cans.
1811 Hydro
Old 02-12-2014, 12:24 AM
I like Rustoleum too. Here's one painted with the marigold and canvas white, under bad lighting. The flash or lighting makes it appear lighter, especially the yellow. I DA sanded, with 220, wiped down with paint thinner, and painted. No primer, just a few light coats and one final heavy coat, but I didn't completely remove the original paint. The colors are real close to the older ones, and the yellow was a decent match to my slightly faded 2082. For less than $5, it's worth painting some test panels to compare for yourself. As for durability, it's still a rattle can, and takes some time to fully cure. A heat gun, before and after spraying, seems to help, just don't get the parts or paint too hot. http://www.onlycubcadets.net/forum/a...1&d=1392181080
Old 02-12-2014, 06:16 AM
nikster's Avatar
nikster nikster is offline
Originally Posted by timbo2 View Post
I haven't used it but I read somewhere that 'school bus yellow' in that brand is a good yellow paint for cubs.
Dupli-color 'school bus yellow'. Bigger auto parts store carry them., & it's close.
NIK
Old 02-12-2014, 08:27 AM
ken6x6's Avatar
ken6x6 ken6x6 is offline
i liked the valspar yellow the best, i got 1 can left that im hanging on to.
i had my buddy paint the white on my 1772 in BMW white. i cant tell the difference can you? (1872 is on the left with original paint)
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 02-12-2014, 08:42 AM
TheSaturnV's Avatar
Another thumbs down here for Majic. Very difficult to get any kind of decent finish, goes airborne and hangs around forever and lays down overspray on everything in a 20 ft radius. As an added bonus, it's tough not to get runs and once it dries, all the sharp edges have almost zero paint coverage.
Miss the Valspar paints.
Old 02-12-2014, 09:47 AM
I never tried to paint a complete tractor with rattle cans but had good luck painting a deck with this stuff in my pos HVLP gun from TSC.
Old 02-12-2014, 11:08 AM
TheSaturnV's Avatar
With my Suburban and 147 restorations, my system HAD been to match auto paint to a selected rattle can color. In the case of the 147, I initially picked Valspar CC yellow and matched the auto color to that. I often paint small batches of things like control levers/rods, etc., and don't want to break out the HVLP and deal with the resulting cleanup and breakage/waste of the hardener which has to be used quickly once opened.
I actually called Majic this morning to let them know their TSC offerings weren't cutting the mustard. The guy sounded sympathetic enough, and his response included "government" and "lower VOCs."
There ya go.
Old 02-12-2014, 11:13 AM
TheSaturnV's Avatar
Here is the Valspar stuff, still available on Amazon for $10.
http://www.amazon.com/Valspar-5339-2...pr_product_top
