Old 03-22-2016, 06:00 PM
charlie105's Avatar
charlie105 charlie105 is offline
Default hydro leak
Ol'George; Thanks I'll try that. I had some concern that a solvent might only drive the paint deeper into the vent material, but it should get most of it off.
Old 03-23-2016, 08:40 PM
SharkyOhio's Avatar
SharkyOhio SharkyOhio is offline
Default Permatex equivalent
The 515 is a better choice for the expansion plug. I use the same thing, only in Permatex. Loctite brand is twice as much for the same stuff last time I priced it.
Thanks for the information and tips!
BTW, what is the Permatex equivalent for Loctite 515?
Tractor #1--1972 Model 149 with rear lift
Tractor #2--1972 Model 149 with rear lift
1A tiller w/both extensions, 38" & 42" Mower Decks, Wheel Weights, Ohio Steel Fabricators 10" mold board plow, two 42" snow blades, QA-42A Snow Thrower, Brinly Sleeve Hitch
Old 03-23-2016, 08:46 PM
It's just called "Permatex Anaerobic Flange Sealant (or gasket maker)"
Old 03-25-2016, 03:16 PM
SharkyOhio's Avatar
Default Permatex #51813
Okay. I split the tractor again today, and I removed the expansion plug. I was very careful not to get any drill shavings into the bearing behind the plug.
I was able to find some Permatex #51813 anaerobic gasket maker. I am now waiting for the new expansion plug to arrive.
