Old 12-02-2013, 03:39 PM
Originally Posted by otcp71 View Post
It's a simple small pond waterfall pump I had laying around.
I have one of those Northern Tool 15 Gal 12 volt powered sprayers. I think I can take the wand off and replace it with a tire chuck and let it rip.
Thanks for the idea
Old 12-27-2014, 05:46 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Well 5 months later I noticed that my 20 year old tires have some seepage I will be using tubes from now on.
I don't know what that was all about. I haven't noticed any thing since I posted that. May have just been condensation on the rims.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 02-04-2015, 11:18 AM
CubCadet129 CubCadet129 is offline
I always tube a loaded tire. Keeps the rims from rusting. I'm not sure how much your tires weigh altogether, but I weighed mine before I put them on once. I use liquid calcium. Altogether, (rim, tire and fluid) weighed right at 100 lbs.
You can't fill tubed tires with liquid.
Old 02-04-2015, 11:29 AM
Shrewcub's Avatar
Why not?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 02-04-2015, 11:55 AM
I went in to a local Napa and asked them and that's what they said
Old 02-04-2015, 11:58 AM
jimbob200521's Avatar
Definitely something you can do
-Ryan
Old 02-04-2015, 01:11 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
They also can't look up what tail light bulb is needed for a 1981 Ford pickup truck without knowing if it has air conditioning first.
Old 02-04-2015, 01:12 PM
DoubleO7's Avatar
That is true!
Unless you let the air out of the tube, there is no space in the tire for the fluid.
When you pour the fluid in via the bead.
Old 02-04-2015, 01:20 PM
Shrewcub's Avatar
Originally Posted by DoubleO7 View Post
That is true!
Huh? When tubes are used, the fluid is put inside the tube via the valve stem.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 02-04-2015, 03:01 PM
DoubleO7's Avatar
LOL, think about the wording.
Tags
tires, weights
