#21
This seems like a timely subject because my 1811 has just started to run hotter than usual and the idle has become unstable after it heats up. It has been rock solid for almost 5 years without any issues. I can smell the extra heat that was not there before if that makes sense to any of you. It is like the engine now puts out a hot oily smell that it never had before. I would suspect that something in the carb has probably made it run a little lean and that messed up the idle as well. Anyone know the best place to start to look for the problem?
1811 Hydro "Failing to prepare is preparing to fail".
#22
your having the same problem im having. |
#23
Just out of curiosity, did either of you ever find a solution to your problem?
-Ryan
#24
I agree, a lean carb makes crazy (and damaging) engine heat in any motor, and it does not take long to get hot either.
#25
been waiting on a carburetor kit to rebuild it.
