#21
![]() Quote:
#22
![]() Quote:
Doug 126 Creeper,H lift,Deck, Sleeve hitch, B Plow, Weights 129 Deck, Blade, Weights 1200 Creeper Deck: 1250 B Tiller odd deck 782R with power steering ![]() ![]() ![]() ![]() ![]() JD 110H:JD 112H |
#23
![]() Quote:
here are a few pics from my current project. |
#24
Wow.....
Ummmm you have to put a support bearing near that love-joy, or it's gonna be bad when it comes apart. Don't bother saying you already had it running. That isn't going to work. Can't use a love-joy and u-joint combo like that without a support bearing. Next issue.... I don't see any room left to mount the 3rd link for the 3pt..... Issue 3: The reason that 3ph arms have a ball socket on them is because they need to flex. Without them, the hitch will break. The rear implement needs to be able to move independent of the tractor. Too rigid is bad.... I have seen one built as you did before. It lasted a while before it broke. Issue 4: As long as the arms are, you won't be able to pick up very much. No need for them to be that long. Issue 5: The plate the pump is mounted to is too thin. It will crack from vibration, and it won't be long. I'm sorry to be this way, but your design needs a lot of rethinking...... |
#25
![]() Quote:
Steve |
#26
just need to fab up a bearing mount on that trans plate and it should work.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
