Old 09-27-2013, 07:09 PM
Originally Posted by Cbary124 View Post
Okay so I know I'm getting spark now. I had the coil hooked up back wards. I'm getting spark. Still won't start. So now I'm going to check for compression. I'm guessing the carb will need rebuilt. Or at least cleaned up. I haven't touched it.
You won't be able to accurately check compression on that engine. It has an automatic compression release (ACR).
It's not getting fuel so I took the carb back off and I'm trying to clean it. Any help?
Any help to what? Clean the carb?
Disassemble it, make sure the jet in the center where the bolt for the fuel bowl goes is clear of debris. Blow out all passages with compressed air. Buy a carb kit. Reassemble. Drain fuel tank. Flush with new gas. Clean the sediment bowl. Replace the fuel lines if it has been sitting for more than a year.
Old 09-28-2013, 11:37 AM
Cbary124 Cbary124 is offline
I ended up just taking the carb off and taking it all apart. Cleaned a lot of carb and choke cleaner in it and that helped a lot. I also let the carb and the parts sit in gasoline to help clean it. I then show compressed air threw it to clean it all out. Put it back on and she starts up every time. Now my issue is my throttle isn't set right. It's like wide open all the time. How do you set the throttle. I also need to adjust the screws in the carb. Need help there as well. The clutch doesn't disengage so it's always going. I can't get it out of gear without turning it off and trying to force it. How do you adjust the clutch?
Old 09-28-2013, 12:16 PM
You need to try and use the service manual. They can be found in the technical section of this site.
To save you the time....
Here is the link to the tractor chassis manual..... 1X4/5 Chassis
Here is the link for the engine..... Kohler K Series
Tags
124
