Old 10-23-2013, 11:50 PM
Nightow1 Nightow1 is offline
The finished product, well almost RESCUE11 and I still need to make a bar long enough. It came out great. Also installed a oil pressure gauge and relocated my hour meeter to the right side under hood.
Old 10-24-2013, 12:00 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Yeaaaaaaa!
1- 1200 in pieces
1- 1864 in pieces
Old 10-24-2013, 06:07 AM
Nice job! You are ready for the white stuff now!
Old 10-24-2013, 09:38 AM
Im having the bracket on the blade for the rod fabricated and enlarged by 2" both in height and length. This will help the blaxe height since the subframe is longer than the original. Hope to get a cew more inches of travel out of the blade once installed. Right now we are only getting like 6" from the blade to groung . Would like a little. More.
Old 10-24-2013, 11:24 AM
Great job! I sure wish my blade lifted a little higher. It only lifts 3" from the ground.
Old 10-24-2013, 11:32 AM
what should they lift to? Is there an average height?
Old 10-24-2013, 12:06 PM
I figured it should lift it a little higher. When I had the blade on my 100, it lifted it a lot higher.
Old 10-24-2013, 01:30 PM
cubby102's Avatar
cubby102 cubby102 is offline
I've noticed the newer hydro lift setups don't lift near as high as the older narrow frames or their manual lift sisters. That's the main reason I don't use hydro lifts
Old 10-24-2013, 05:58 PM
I can get my blade on my 147 8" at max. height.
Old 10-25-2013, 10:37 AM
Rescue11's Avatar
If you ever look at the hydraulic cylinders on an 82 series and newer versus the quiet lines and older, the lift cylinders are different. 82 series and newer have a 3 inch stroke by approximately 2.5" bore. Quiet lines and older have a 6 inch stroke and approximately 1.25" bore. Obviously the cylinder with the largest bore will have the most lifting power if placed under the same hydraulic pressure, mechanical advantage, etc... Uppers feel free to critique this, but I believe Cub Cadet used a larger bore cylinder with a shorter stroke to allow the cylinder to be mounted lower in the frame for various reasons. This being said, the closer the working end of the cylinder is to the rock shaft the less leverage it has. Thus the larger bore is needed to overcome the decreased mechanical advantage. I have to cautiously assume the reason for the shortened stroke on the large bore cylinder is due to a law in physics as well. Newtons Third law: When one body exerts a force on a second body, the second body simultaneously exerts a force equal in magnitude and opposite in direction to that of the first body. The closer the working end of the cylinder to the rock shaft, the further the travel of the working end of the rock shaft, i.e. deck lift and cam lift for blowers, blades, etc.... Again, making a guess, Cub Cadet did not lengthen the stroke of the cylinder due to either useable space inside of the frame or they were satisfied with the lifting travel. Sow any way that is my
1- 1200 in pieces
1- 1864 in pieces
