#21
Looks exactly like the deck lift on my Tank LZ60,but with a few mods made to it.
#22
Any updates on this, maybe a video? I have been kicking this idea around since I do not have a helper spring on my 129 and my tiller is heavy. I was looking at this one:
http://www.ebay.com/itm/5-31-STROKE-...item3f13ea020c Anybody else use an aftermarket actuator and how is it holding up? Thanks.
"O", 100, 129, 149, 169 |
#23
Without a slot on one end of the actuator, how does the deck float?
#24
I suppose if you have your heart set on an electric lift, that one would be alright.
However, I would bet that there are sponsors and members on this very site that can fix you up with everything you need to install a factory hydraulic lift on your 129 and probably cheaper than the price of that electric lift. Electric lifts were a wonderful addition to the Cub Cadet line, but they had a tendency to be slow, not very powerful and they wore out/broke much easier than the hydraulic lifts. If you were to install a factory hydraulic lift on your 129 you would not need to drill any new holes or do any welding on your tractor, it would be a clean bolt on project that should give you years of trouble free service and plenty of power.
#25
I do think the hydro lift is the most ideal setup, I guess I should call a vendor and see what they have and for how much. Thanks
#26
That looks like the same set up I got at a thrift store here .
Mine has a release valve I posted a pic on another thread hope to install it this yr, thanks for the picture . |
#27
http://www.onlycubcadets.net/forum/s...9&postcount=12
Looks like the same actuator i used to replace the factory elec lift on my 147 Works really well
----------------------------------- 106 Needs a clutch-------107 (Lent to my brother) 123 w/hydro lift & qa36--126 w/creeper and lift 127 restored--------------129 50" mowin machine 129 w/hydro lift-----------147 plow horse w/tiller 149 auction score---------782 KT17SII |
#28
I believe that he sold it.
#29
I could see wanting it to float with a deck but how about a tiller, I would think I would want the down pressure, no?
#30
The tillers are hung from chains, so they float on their own. If the tiller hits something hard under the surface the ride can become pretty violent. If it had down pressure, I suspect real damage could occur... not only to the machine but possibly to the operator as well.
