Old 11-15-2013, 10:53 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
would replace the current switch... no new holes! I didnt diagnose his problem. I stated how less is more. simply put!
1- 1200 in pieces
1- 1864 in pieces
Old 11-15-2013, 06:59 PM
lawman lawman is offline
I replaced the old solenoid with a new one, it is still not working only have hot to one side of the switch, the side where the hot wire attaches, the other side of the switch where the ground terminal is I don't have fire, I may go the other route with the other style switch and see if I can make that work, thanks for all the help
Old 11-15-2013, 07:05 PM
Go back to post #15 and read it. If it doesn't work that way something else is wrong.
Old 11-15-2013, 07:27 PM
Going to try the advice of R. Bedell, it looks a lot simpler. I thought there would have to be a better way to make it work
Old 11-18-2013, 06:38 PM
Tried the simple wiring diagram and switch, worked great. I wished I had done that before I spent money on all of the other stuff.
Old 11-18-2013, 06:47 PM
When it comes to electrical stuff Dr. Roland is hard to beat. He has bailed me out more times than I care to admit. Glad to hear you Got Er Done.
Old 11-18-2013, 06:55 PM
Originally Posted by lawman View Post
Tried the simple wiring diagram and switch, worked great, wished I had done that before I spent money oy all of the other stuff
Glad to hear you got it working!
Old 11-18-2013, 10:12 PM
Great news! Glad you got it!
