Old 11-26-2013, 11:23 AM
All good pictures....It's giving me some ideas and thoughts.
Something along these lines also has possibilities.
http://www.tractorforum.com/f154/atv...k-images-1069/
Old 11-26-2013, 10:01 PM
juniors1282's Avatar
Sam beat me to the pics. I haven't had time to take better pics. Of the mule and mount on mine yet with all the weather we're having been pretty busy.
1966 IH cub cadet 102x2
Old 11-27-2013, 11:08 AM
inspectorudy's Avatar
I agree about removing and re-installing the deck. Man oh man, that is getting to be a bear of a job. I use the motorcycle lift that I bought from Harbor Freight ($59) to lift the front up but it is still back breaking. I thought if I got a JD with a shaft drive deck it would be a lot easier to remove and install the deck but I was wrong. It is different but it is still back breaking. I haven't seen the "Drive on" deck that they show on TV, in real life, but it looks a whole lot better than getting on your hands and knees.
1811 Hydro
Old 11-27-2013, 01:14 PM
This is a homemade set up that one of our members bought.
Am I missing something in the pic?
Wouldn't that deck be running backwards??
Old 11-27-2013, 01:49 PM
John
I think the belt needs to flip as it comes off the mule drive to reverse the rotation. If you look at the pulleys you'll see that they are aimed to do just that. The guy that sent me the pics had just bought this from a PO and wasn't sure how it all went together if I remember correctly.
Old 11-27-2013, 01:54 PM
maybe the blades are different but is is turning backwards
Up to 534 and counting...
AHHHH.... so the belt is set to criss/cross after the mule/before the deck. Yep, that'd work.
Old 11-27-2013, 02:01 PM
Yep the way it is in that pic the blades would be turning backwards. I'm pretty sure the belt just needed to criss cross. I'll e-mail both of you a higher rez pic so that you can see the pulleys on the mule drive better.
Old 11-27-2013, 02:04 PM
Please, and thank you. I do want to see that closer.......
