Old 12-02-2013, 07:41 PM
turbo460 turbo460 is offline
Thank you Sawdustdad that's what I was trying to say.. Their is no doubt in my mind that it will hold....
Old 12-03-2013, 06:00 PM
sgirdham's Avatar
sgirdham sgirdham is offline
Even if the stock clutch setup was "ok" for novelty use, why would a person put countless hours of design, engineering, fabricating...etc to build a sweet looking articulating tractor with a 50 hp diesel if he couldnt count on it having the pulling power of a small tank? The clutch is a very important variable in that equation. From my experience, with 100 lbs wheel weights on each tire, i have wore out a stock clutch in a short period of time pulling large loads of firewood. Jonathan is correct on this one.
1981 IH Built 782- 44" deck
1650 dual stick
71 "121" round fender and replacement k301 carlisle tru powers and v61
Old 12-07-2013, 11:54 PM
cadetbemo cadetbemo is offline
Thank you sgirdham, if you are wearing out stock clutches pulling loads of firewood that is all the proof that I need. The heaviest work this tractor will be doing will be in the woods. Mostly dragging trailers loaded with wood. Maybe a rare case of dragging a log. What I've learned through studying Cub Cadets would lead me to a agree that a stock clutch is good up to about 20 hp. My sole reason for running a manual trans is to get as much HP to wheels. I don't expect to use the full 50 hp, chances are I could run a lesser engine, if I had one. Thank you to all, this thread and some private conversations have helped me answer some more technical questions about stock clutch limitations.
I don't have to worry about any class restrictions in the woods so there is no reason for me to risk dragging a dead machine out of wood with a blown clutch.
Old 02-05-2014, 05:12 PM
cubfan's Avatar
cubfan cubfan is offline
School dismissed(lol).
