#21
Gauges look good Sam!
#22
I assume that the shut-off is NLA from Kubota?
#23
Sam,
Here are some pics of my setup. Only had her a couple months. Notice I did say I assumed it was factory....... I'll have to look at it closer to see if there's a wire somewhere just hanging out. The shutoff works great. A lot better than the throttle shutoff on my other smokers. After looking at the pics again, if you look at the last pic, just left of the fuel filter, it looks like an unused plug. Prolly for the missing electric solenoid.
Josh Diesel Cub Cadets........... |
#24
Jon
It's not a Kubota item.
#25
#26
Nice warm day today so I got a few things done. Removed the steering shaft and the drive shaft. Then I gave it a final pressure washing before I start putting it back together. Cleaned out the parts washer, it was getting nasty. I'll be doing some work on the rear end and dirty fluid in the parts washer doesn't get it for me when I'm doing hydraulic or gear work. Cleaned up the shop a bit still more to go before I open the rear up. Plan is to get the engine back in first so I have space on my work bench.
#27
I wondered, but didn't take the time to look. It's not unusual at all for a shut down solenoid to be supplied by the manufacturer of the "vehicle". Just curious, if I could get a replacement part number, would you, or anyone else be interested? I personally, would just do the kill cable thing. Just asking because we run into those solenoids being NLA, or too expensive from various companies all the time. There are "universals" out there.
That's funny. I did the same thing today! Mine had about 2"-3" of "slop" in the bottom. ![]() Next on the list.... the oil burning furnace, and the jet tank.
#28
The way the shutdown works if I have it figured out is it will shut the engine off with the key or the safety switches, then when you go to start it the solenoid strokes in the opposite direction. ![]() I have a cable and that is what is going on it. Yep I had mud in the bottom of the parts washer. NASTY. One of those jobs I hate.
#29
You can look at the link below. I think the Kubota 1A externally switched kit is correct for the 1782, but I have not bought one yet to know for sure. Woodward shutdown solenoids SA-4269-12 (Externally Switched; 3 wire) $170.00 (This price was current as of Nov. 12 when I asked about them).
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
#30
