Old 12-08-2013, 08:01 AM
Just looked at the install directions for the valve kit for the Cyclops and they only mention 1 O-Ring on each side of that adapter, maybe the 3000's are different. Can't say because I have never seen one.
Old 12-08-2013, 11:16 AM
The 3k tractors only require 1 ring per side also. I will get the adapter and some rings out to you this week Sam.
Old 12-08-2013, 08:44 PM
V30crewcab V30crewcab is offline
I would be interested a pair of them as well.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 12-09-2013, 09:56 AM
Originally Posted by KayakDon View Post
Thanks to all your help. I bought the needed valve from SamMac, and soon I will be asking about the needed lines. Are the hydro parts from a 3200GT or any newer tractor adaptable for my 2182?
I did find the 711-3294 part for $9.71 at http://www.cubcadetpartsnmore.com/ They seem to have good prices on belts. Don
Don
Big thanks for this post Just checked pricing on a bunch of seals and gaskets I need for my 1782, www.cubcadetpartsnmore.com had better pricing than every other place I looked at.
Old 12-09-2013, 05:17 PM
jubilee's Avatar
jubilee jubilee is offline
SamMac, I would like one of those adapters also please.
The diagram for the 365 3-point hitch shows a 721-0492 oring backup in addition to the 721-3021 oring on each side of the adapter.
___________________
Jim
782 w/Command 18,
1862 not running;
IH 42 inch blade; off brand cart
Old 12-09-2013, 05:45 PM
LiamD's Avatar
LiamD LiamD is offline
Default 2182 dual hydrualics
Hi Sam,
I would like whatever is needed to convert my 1882 as well. If you can please PM me when your ready.
Thanks Mike
Old 12-10-2013, 06:00 PM
Captain B Captain B is offline
Hi Guys,
I am trying to do this exact same project to a 2084. Just picked up a plow for it and want to make it fully hydraulic. Any help would be great.
Sam - you don't happen to have another one of those valves laying around do you? I see I just missed one on eBay a few days ago :-(
Also, this part you are having made is what stacks these valves together, right? If so, I am in for 2 of them!
Thanks guys!
Old 12-10-2013, 07:00 PM
TIMCRUTCHER TIMCRUTCHER is offline
I looked at the 3000 blade angle kit that required adding a valve. That is where I got the opinion that it needed both o rings and back up rings. I may have been wrong, but only wanted to do it once.
Old 12-10-2013, 08:15 PM
jubilee's Avatar
SamMac- I just re-read these posts and realized I should have asked you to reserve 2 of the adapters for me rather than 1.
Thanks!
___________________
Jim
782 w/Command 18,
1862 not running;
Old 12-10-2013, 10:23 PM
Sam Mac or anyone else, can you confirm that the part number I need for and additional hydraulic valve for my cyclops SGT, model 2084 is 717-3308a?
Then I will just need to make a handle to operate the valve, correct?
Thanks for the help guys!
