#21
Sorry I can't help. The unit I used was not slotted.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake |
#22
![]() Quote:
When installing the actuator brackets did you do so with the actuator at 1/2 mast so to speak? I'm guessing, blade and triangular mount at right angles (90 degrees) when positioning your brackets? 1st Cub, only had the plow a month. It is a real pain having to get off 'n on the Cub to angle the plow. And, the engine shuts down when up off the seat. ![]()
Tankman '95 CCC 1641 Eastern PA USMC |
#23
![]() Quote:
#24
I'd love to do a power angle. I'm not that creative, so I'd need to know what model actuator or cylinder would work and a little help making the bracket.
I wonder if a manual angle could be added? The old Sears snow blade has two rods. One you step on, which unlocks the blade. The push-pull rod actually angles the blade. It works amazing. The trick would be how to release the blade lock with a push/pull rod?
1973 Cub Cadet 149 2023 John Deere X590 Farmall B sitting in relative's barn |
#25
![]() Quote:
These pictures are not the best and I don't have good access to the blade etc. right now. The conduit shown here is connected to the blade. 149 Foot Control Pic by Don Bowers.jpg A cable is attached to the locking pin, ran up through an eye bolt and over to a bracket (4 inches or so long) attached to the bottom of the conduit. It’s hard to see the bracket in this picture. You can see the discoloration on the conduit where the bracket was attached. 149 Pic by Don Bowers.jpg To change the blade angle you rotate the conduit, this pulls the pin up, unlocking the blade. Then you just push or pull on the conduit to set the desired blade angle. Works good. Good luck, Ike |
