Old 12-22-2013, 05:44 PM
Giotundo Giotundo is offline
Thanks again fellas
Old 12-22-2013, 07:27 PM
EricR's Avatar
EricR EricR is offline
Good deal to hear you got it running. We just replaced a wiring harness on a 102 and it will be better than old. I bought mine from our forum member Mike Lymar < I think that's how you spell it, and couldn't be more than happier.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 12-22-2013, 07:32 PM
Not sure why, but sometimes splash from a pressure washer,steam cleaner,etc will get inside and wreck the coil.
If drying out points and wiring doesn't fix it, coil may have failed.
Had that happen on a couple of cotton pickets and a combine many years back when I worked at an IH dealer as the steam clean operator.o
Old 12-22-2013, 10:20 PM
Originally Posted by Giotundo View Post
Thank you for all the insight guys! Got it runnin today the positive wire on the ignition coil was majorly burned up. Replaced that all the way back and started right up. I'll end up getting a new wiring harness because there's a few more that aren't in the best condition but it's running!
Glad your cub is running again!
