Old 01-09-2014, 12:22 PM
Muzzy Muzzy is offline
Did you measure the belt that you have? Maybe it's not 28".
Edit to add: I just measured a 3/8 x 28 Gates belt and pulled tight it is about 13.5" on the outside. That belt fits my qa36.
Old 01-09-2014, 01:27 PM
cmouta's Avatar
cmouta cmouta is offline
I'll check it out when I get home, thanks for checking. Of course I bought two just in case
Chris
1968 Cub Cadet 105
Old 01-09-2014, 04:54 PM
Originally Posted by cmouta View Post
Is the adjuster supposed to look like this?
that IS reverse thread and that castle nut makes sense because there is a hole for it which is not the case with the adjuster I have. I'm starting to think I got a little hosed on this snow thrower from craigslist. The belt I was given was too big, the lifting rod was too short. now this...
I purchased material, I have begun machining and will be offering these shortly.
Jeff
Old 01-09-2014, 05:48 PM
jimbob200521's Avatar
Jeff
Is there a way to incorporate some kind of socket head on it to make it able to be turned with a wrench? Even a nut to put a socket on or even a female socket adapter (like the fill plug on older Cub rear ends have) would make it easier to get to from time to time. Just a thought, looking forward to seeing what comes out of your shop!
-Ryan
Old 01-09-2014, 05:51 PM
Yes, since I make them, I can do pretty much anything I want.
I can weld a nut on the end instead of the handle so a 3/4" wrench or socket can be used.
Old 01-09-2014, 05:52 PM
cmouta's Avatar
Thanks Jeff but I the nut on my QA plate was right handed threaded to match the adjuster I had as well, I wouldn't be able to use this without swapping it that out.
Flattened my belt out, it's about 13.5" on the outside as well. This is it sitting at rest, with slack on the belt and out of room for adjustment.
Chris
1968 Cub Cadet 105
Old 01-09-2014, 05:55 PM
Now that I would be in for!
-Ryan
Old 01-09-2014, 06:27 PM
http://i802.photobucket.com/albums/y...psue063ifh.jpg
That belt looks like it sits down in there pretty far. I wonder if the sides are worn
A shorter belt would work. Did you run the belt on there yet? If not, you may be able to return it .
I could make a right handed version of the tensioner for you if you want.
Entire assembly or just the left handed screw ?
Old 01-09-2014, 07:31 PM
Actually...mine is right handed
-Ryan
Old 01-09-2014, 07:46 PM
I can make the screw right handed. Can you get me the overall length from the handle ( where the rod starts ) to the end of the threaded rod?
