Old 02-10-2014, 10:44 PM
jcsmith jcsmith is offline
How about Rim Guard tire ballast?
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 03-06-2014, 08:54 PM
CAO65 CAO65 is offline
Update on wheel weights:
I called Steiner regarding the wheel weights I was looking at, and the man on the phone gave me dimensions that fit my GT2000 perfectly. So, I advised him of the tractor I plan to put them on, and the man said the weights will not fit as my Cub Cadet is made in China. I advised him my tractor was not made in China, and great customer service as he was providing, argued with me that the weights would not fit, and my tractor is made in China. At this point, I ended the call. I looked on eBay and found a man in New Hampshire looking to sell the same type of weights so I emailed him for dimensions. He said they came off I think a Cub Cadet 1572, and the dimensions were identical to the ones at Steiners. I bought them, and put them on the inside rims of my GT2000. And, the color of them match my existing rims, and they fit like they belonged. A fellow forum person also told me they would not fit, but I went against the grain, and I am glad I did.
Old 03-06-2014, 09:08 PM
john hall's Avatar
They look nice, pretty much like that is where they were intended to go! I got to ask, what was the motive for putting them on the inside?
Disclaimer--I've never fooled with weights on a Cadet, although I have one that could use them, fluid, or ag tires---or any combination of the 3.
Old 03-06-2014, 09:52 PM
I tried them on the outside and inside of rims, and I thought they looked better on inside. I only wanted a little extra weight for cutting sideways on a hill in my yard. The yard also has soft wet spots so I didn't want to go too heavy. The tractor already weighs over 1,000 pounds with the stamped deck as it is.
Old 03-06-2014, 11:01 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
The wheel weights look like they were made just for your tractor. I'm glad it all worked out for you.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 03-07-2014, 06:16 AM
Good to hear you got fixed up.
Old 03-07-2014, 09:27 AM
Good that they do fit, learn something new every day.
Old 03-07-2014, 09:30 AM
Sure do.
I wonder why the newer ones do not list them as a option?
Up to 534 and counting...
Old 03-07-2014, 10:46 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Sure do.
They went with the weight bracket and "universal" suitcase weights.
Now they do not have to handle wheel weights that only fit 12" rims.
Old 03-07-2014, 10:56 AM
I noticed Cub Cadet doesn't list wheel weights for this tractor just suitcase weights. Yet, there are 4 square holes in the wheels for mounting weights. My local Cub dealer can order concrete, plastic covered ones, but I don't like them as much. Another Cub dealer in PA had cast iron weights they order in bulk that fit on outside of rim, but they stick out too much. The suitcase weights are great if one has a front loader, blower, or blade, but I don't think they are for cutting grass and for general stability issues. I'm just glad I got them on, and they fit and look good. Now, bring on Spring.
